suzuki DT90 water warning alarm & lights
zuki5183
I have a 1989 DT90, water alarm sounds and red lights come on at idle and only go off after revving engine or going about 8mph. Brought to dealer to fix, they replaced impeller, but problem continues.
Read other threads that seems to indicate my problem is a flow sensor. My question is, Where is the Flow Sensor????
Brown's Point doesn't list a part called that, tho there are 2 cooling water sensors, and an engine temp sensor....
deejaycee_2000
Re: suzuki DT90 water warning alarm & lights
There are a few sensors, engine temp sensors, water cooling sensors etc. you have to check all of them anyway to see if they are working properly or not.... the flow sensors are the ones on the block ...
