  #1
Old August 2nd, 2009, 08:37 PM
MGA MGA is offline
Default Buzzer- Yamaha 1986 PROVJ 150 HP
I was running for about 20 minutes at 4100 rpm and the buzzer goes off.
As far as I know the alarm buzzer goes off for low oil in the outboard tank, low oil in the inboard tank, low oil pressurre, and overheating. I have warning light for the first 3 and recently replaces the oil pump, and anything to do with low oil will shut the engine down to 500 rpm which did nor happen.
The p hole was putting out a good stream, I put my hand on the top of the cylinder which was hot but not too hot to touch and hold my hand on. Re started the buzzer still going, then stopped, I ran the rest of the day at 3600 rpm not problems.
Does anyone have any ideas of what to check ad how?
  #2
Old August 3rd, 2009, 07:24 PM
rodbolt rodbolt is offline
Default Re: Buzzer- Yamaha 1986 PROVJ 150 HP
NO remote tank level alarms other than a yellow or center bar indicate on the tach.
if the remote tank filter is clogged its possible at high speeds for the engine tank level to drop faster than oil can be transfered.
what visual indicates are you getting at the alarm condition?
also no oil pressure on that engine.
any alarm condition will limit or reduce RPM to about 2000 RPM not 500.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
oil coming out the carb PROVJ 150 MGA Yamaha & Suzuki Outboards 2 May 1st, 2009 08:32 AM
Oil coming out of one Carb - PROVJ 150 1986 MGA Yamaha & Suzuki Outboards 1 April 28th, 2009 10:05 AM
Does a 1986 DT-85 have a temp warning buzzer ??? bowhuntrrl Yamaha & Suzuki Outboards 0 August 2nd, 2007 11:17 PM
1986 40hp Johnson buzzer on with water running ba_50 Johnson & Evinrude Outboards 25 November 15th, 2006 07:26 AM
Need overheat buzzer,1986 Johnson 90 hp. mrtool2u Johnson & Evinrude Outboards 1 September 14th, 2003 07:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
