Hi guys!
Having some trouble with my MR 170, 86-mod.
When engine is cold I rarely or never have any starting troubles.. But after engine reached operating temp. and I try to crank, the starter sometimes will not turn at all. In most cases it will crank the first time, but 2-3'rd time it dies out, as if the battery is empty?!
I've got brand new Maxima battery, battery charging at 14.2V at running, installed a new starter solenoid, startermotor is about 3-4 years, new battery cables and pole-clamps and the ignition switch was new 2 years ago..
When engine running it runs smooth and perfect, no problems at all..
I'm beginning to run out of ideas of what could be the problem causing this..???
Thanks in advanced!
Thanks in advanced!
