  #1
Old August 2nd, 2009, 10:24 AM
garyj garyj is offline
Default '87 150 Mercury XR2 Overheating at High RPM's
I am having overheating issues with a 150 XR2 above 3500 rpms. It runs about 170 degrees at 3500, but anywhere above, it gets hotter as the rpms increase. At wot, it will set the alarm in about 3 minutes (gauge reads 250). Things I have done to correct this issue (with no positive results).
1. Replace water pump (tried two different pumps)
2. New t-stats
3. New poppet valve
4. New head gaskets - milled heads (checked for any obstructions while down)
5. New center exhaust plate divider gaskets.
6. New powerhead to drive shaft adapter plate gasket (did not replace the drive shaft adapter plate to leg gasket (any thoughts?)
7. Good pee stream. Installed water pressure gauge. 6 psi at idle, 18-20 psi at wot.
8. Installed temp gauge on port side. Gauge on port side reads HOT when alarm on starboard side sets. Both heads are getting hot. I have shut down immediately after the alarm sets, then turned the ignition back on, it still reads HOT. Gauge and alarm seem to be working properly.
9. Installed jack plate. Let leg down in further in water for a test (eleminated any potential water pickup problems)
10. Checked timing
11. Checked for correct carb jet size
Any thoughts?????? gary
  #2
Old August 2nd, 2009, 10:47 AM
CharlieB CharlieB is offline
Default Re: '87 150 Mercury XR2 Overheating at High RPM's
The exhaust and water passages are right next to each other, a gasket failure there, on either side of the adapter plate will allow higher pressure water to bleed of into the exhaust, thus reducing cooling when it is most needed, at or near WOT.
18 - 20 psi @ WOT seems a bit too high, as if the poppet is not opening. Double check that the poppet SEAT is firmly i place and not moving out along with the valve, thus not opening the flow path. You should be able to see the small pressure drop as the poppet opens.
Is this a new problem or did you get the boat with this problem?
  #3
Old August 2nd, 2009, 11:47 AM
Thanks so much for the quick response!! I have actually been dealing with this same issue for about 5 years! It is an ongoing project. When I bought the boat, the overheating was an issue, but I thought, how hard could that be to fix? Well here I am.
When I replaced the poppet valve, I also replaced the rubber seal grommet. I've had it in and out a few times. Haven't seen anything wrong as far as I can tell. I did at one time completely remove the poppet valve and took it for a test run. With no poppet valve, it still ran hot at high rpms. No change at all.... (still had very good pee stream at wot)
gary
  #4
Old August 2nd, 2009, 03:03 PM
j_martin j_martin is online now
Pressure is within bounds. Should be cooling.
Perhaps the answer is on the other side of the equation.
What's your timing. That engine has an advance module on it that could be over advancing the timing. Try a run with it disconnected.
Check your plugs. Could be running a bit lean at WOT. The way to check it is to run WOT as long as you can, then shut down suddenly (make arangements so it is safe, and you can do the next step.) pull the plugs and examine them. The insulators should be roughly a shopping bag brown. If some or all of them are too clean, yer too lean. BTW over oiling can cause this.
What's the part number on your carbs, and what's the jet sizes, especially main and vent?
hope it helps
John
  #5
Old August 2nd, 2009, 03:07 PM
Just had a thought. Check the dump hose on the thermostats, between the tattle tale T and the adapter plate. If it's plugged, that would allow a very strong tattle tale and still not accomplish the extra cooling the t-stats are supposed to provide.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercruiser 5.7 overheating above 3k RPM's MCS59 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 May 25th, 2009 09:28 PM
4.3 GXI overheating at higher RPM's LPeak42 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 May 25th, 2009 05:05 PM
Mercury 115 still overheating when under load or high RPMs adnet99 Mercury & Mariner Outboards 12 June 10th, 2008 08:02 PM
Overheating at High RPM's bayhawk14 Yamaha & Suzuki Outboards 3 April 25th, 2006 03:35 PM
81 OMC Inline - Overheating at High RPM's pls5792 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 May 23rd, 2003 11:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
