Re: 1994 Mercury 175 XRI EFI, Loss of Power under Load
Any more than an idle will empty a barrel in about a heartbeat.
The barrel is great for setting idle mixtures and idle speed, however, carbed motors with adjustable idle mixtures MUST BE set RICHER than best idle speed in Forward gear to provide the additional fuel necessary for acceleration.
Too lean an idle and large application of throttle the motor coughs and dies.
Back out the idle mix screws an 1/8 turn and retest. Ideally, make adjustments in even smaller incremental turns until on a full WOT from idle there is NO hesitation in the slightest.
