Bugsy's Baits
- Jul 9, 2009
- 4
I have a pair of 1999 EFI two strokes on a 30 ft Trophy with 105 hours on the engines. Both engines run fine and boat tops out at 51 mph. When I troll with starboard engine for 3 hours or so after 20 min run and have the port engine off(hot soak). When I restart the port engine it idles fine for about 1 min and stalls. If I pump the primer bulb 6 or 7 times it fires right back up and no problem. I changed both bulbs and it still does this intermittently. If I let the boat sit overnight and restart everything is ok. Seems like only with the hot soak it does this. Is it a vapor lock issue or fuel pump losing prime. I think there is a vacuum lift pump on the side of the case and then it feeds to the high pressure pump. I may take fuel psi gauge with me and test on water. Any suggestions. Thanks!
Please feel free to call if you like!
Bugsy
248-88-BUGSY
www.bugsysbaits.com
Bugsy
248-88-BUGSY
www.bugsysbaits.com
