Mark42
- Oct 8, 2003
- 9,334
The compression is 120 on all cylinders, but reading the service manual, I just found out the throttle should have been at WOT when doing compression test, so it is probably higher. Specs say 145 to 165, so the motor is low, but even.
Motor starts with just a bump of the starter, idles smooth, and it appears that the CDI and Coils were recently replaced by the previous owner.
The problems with it are:
1) smokey while idling along at no wake speeds. Use Walmart TCW3 oil at a 50:1 mix. I have removed the two hoses and their fittings on the intake manifold that return unused gas and checked for clogs, stuck check balls, etc. Both the fittings have no check balls. Both the fittings are clear at either end of both hoses. Both hoses are clear and can be blown through easily. Spark plugs show little to no carbon buildup. What else could be causing smokey idle and off idle operation?
2) motor makes a kind of "rattly" noise as it winds up under WOT. Its running smooth, but it sure sounds like its going to let a rod loose at any moment. Been doing this since I owned it, but it just doesn't sound right, (or as smooth as my 40 hp Johnson twin). Sound OK at cruising speeds at about 1/2 or 3/4 throttle. Are these just noisy motors? Or does this indicate worn main bearings or the like?
