I have been seeing more questions about hard to start when hot, rough idling, boat stopped running, etc and just wondering if the ethanol in gas is partially or fully to blame. the thread titled 3.0 hard starting has a post with an explanation of the effects of ethanol in fuel and what can happen. the temps are rising and more boaters are getting out now. rocky road submitted this. take it for what it is worth to you.
"ETHANOL AND VAPOR LOCK
Short description:
When the engine compartment becomes hot either by climate or idling, and you use ethanol-blend gasoline it can cause excessive vapors in your fuel line and starve the engine of fuel. The engine can run poorly or stop and will not run until the fuel condenses.
THE PROBLEMS
Vapor Lock
Fuel containing 10% ethanol is called E10. If you have ethanol in your gas, you run the risk of creating vapor lock because of excess vapors.
Ethanol ?boils? at 87?F (at normal atmospheric pressure) and turns from a liquid to a gaseous state. By comparison, most automobiles have their fuel pump in the gas tank, so the whole system remains under pressure unlike boats whose fuel tanks are vented. In a closed system, the higher pressure raises the flash point of the ethanol reducing the amount of vapor that is produced. In addition, most automobile fuel lines are outside of the vehicle allowing them to stay cooler.
Since most boat fuel lines are in the enclosed space (sometimes even insulated) of the engine compartment, normal ventilation will not cool the fuel significantly enough to avoid the potential problems of vapor lock. Furthermore, since the fuel pump in a boat is mounted on the engine (versus a car where the pump resides in the tank) the action of the pump can reduce pressure in the tank to below atmospheric pressure and further reduce the flash point.
Boat engineers are aware of this problem and are reducing the likelihood of this occurring by reducing the suction required by the fuel pump, minimizing hose fittings and bends, and including a quality anti-siphon valve. In existing boats, fuel lines and filters should be kept as low in the boat as possible and tank vents should be cleaned and open.
Heat Soak
Most boats have ?forced? ventilation. Air moves through the engine compartment when the boat moves forward. Heat soak happens after you have been at high RPM and then stop or drift on idle for a while. Because of heat soak the engine compartment will rise to a point where the ethanol will boil
THE CURE
To prevent vapor lock (i.e. boiling ethanol):
Make sure the engine compartment has adequate ventilation.
Relocate fuel lines to be low in the bilge. (The bilge is cooler because it is in direct contact with the water.)
Monitor the engine compartment temperature.
Add (or turn on) engine room blowers.
Keep the tank vent clean and unobstructed.
Short description:
THE PROBLEMS
Vapor Lock
Heat Soak
THE CURE
