  #1
Old July 31st, 2009, 06:58 PM
hbulle13 hbulle13 is offline
Default Low RPM's on 18' G3 Pontoon 60HP Yamaha
Hello,
I have a new 2009 18' G3 Pontoon boat with a F60 Yamaha 4 stroke.
Usual load = 3-4 people, 20Gal gas, 100lb's gear
From the dealer it came with a 10 5/8 x 12 Prop (3 blade alum.).
On dead calm water, it ran about 19MPH(spd gauge) at 4200 RPM WOT
The dealer checked and my throttle is correctly set.
I replaced the prop with a Turning Point Hustler 12 1/2 x 8 (3 blade alum.) and my numbers came out to 20MPH at 5000 RPM's WOT ( in reverse it is VERRY slow now. my trolling motor is faster.)
The dealer said that the motor is supposed to run between 5-6000 RPM, and the ideal point in my setup is about 5700 RPM.
Of course I would like to have as fast speed as possible , but my main concern is getting it to the correct RPM's before I get too many hours on the engine.
Any suggestions as what prop to try next, or anything else I may have missed.
  #2
Old August 1st, 2009, 04:44 PM
hwsiii's Avatar
hwsiii hwsiii is offline
Send a message via Yahoo to hwsiii
Default Re: Low RPM's on 18' G3 Pontoon 60HP Yamaha
Bulle, welcome to Iboats prop forum and we will try to help you as much as we can but without more information no one can help you and I will tell you I need more information than anyone else. But if you would like my help fill this form out and I will help you as much as I can.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don’t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer’s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the forgoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
  #3
Old August 3rd, 2009, 12:48 PM
1. Year, make and model of boat 2009 G3 Pontoon
2. Length, width and base weight of boat, look for boat decal on back of boat 18' x 8' Dry Hull Weight 1340lbs, package weight 2370lbs2a.What is the recommended HP for your boat Max 75HP
3. Number of people and gallons of gas normally on boat 4 People, 20 Gal
4. What do you use the boat for Fishing, Tubing
5. Is it a Deep Vee and if so how many degrees of deadrise NO
6. Year, make and model of motor 2009 Yamaha F60LTR 60HP
7. HP and gear ratio of motor IMPORTANT 60 HP 13:24
8. Manufacturer’s recommended Wide Open Throttle (WOT) range 5000-6000
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches ? how do I figure on a pontoon?
10. Is it a bass boat or does it have a pad bottom NO
11. Does it have a hydrafoil, dolefin or trim tabs NO
12. Make, model, diameter, pitch and whether SS or aluminum prop Aluminum turning Point Hustler 12.5" x 813. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50 4700 RPM 19MPH on board gauges14. Are you at sea level or a higher elevation, give us the elevation in feet 3000ft
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the forgoing could be the reason your prop is not attaining full RPM New engine, dealer says throttle is correct
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop 2 weeks, still not getting correct RPM. Original Prop was 10 5/8" x 12 aluminum (4100 RPM 18 MPH)17. Does the prop show any damage that you can see NO
Want the RPMS around 5600
  #4
Old August 3rd, 2009, 05:39 PM
hwsiii's Avatar
Is this the high thrust motor from Yamaha.
H
  #5
Old August 4th, 2009, 12:58 AM
No,
It is the standard mid range 4 stroke.
Brian
  #6
Old August 4th, 2009, 01:24 AM
hwsiii's Avatar
Brian, will you be running the boat at this altitude all the time and how many people were on the boat when you got these speeds.
H
  #7
Old August 4th, 2009, 11:42 AM
The three lakes I usually go to are 3400, 3652 and 4200 ft.
A little higher than I thought.
The numbers I gave were at the 4200ft elevation.
I was the only one on the boat with those numbers.
With 5 people the same day it ran 4400rpm and about 14-15 mph.
I will usually have 3-4 people on board.
Thanks,
Brian
  #8
Old August 4th, 2009, 02:57 PM
hwsiii's Avatar
Brian I have not forgotten you, I am just pondering.
H
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 150 RPM's Gremlin Yamaha & Suzuki Outboards 27 August 11th, 2009 08:21 PM
87 Evinrude 60hp RPM's( revised question) Tempest 160 Johnson & Evinrude Outboards 5 January 8th, 2009 03:53 AM
Low rpm's 90 Yamaha bcribb52 Yamaha & Suzuki Outboards 5 March 4th, 2005 07:47 AM
1971 60hp Evinrude Triumph low RPM'S under load sockey sally Johnson & Evinrude Outboards 3 August 20th, 2004 05:02 PM
High RPM's, Evinrude 60HP Team Lowes 48 Johnson & Evinrude Outboards 4 July 31st, 2003 08:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
