  #1
Old July 31st, 2009, 06:48 PM
onedesign005 onedesign005 is offline
Default Evinrude 115hp 70's, very stiff flywheel can't turn by hand
I have had this engine for about 2 yrs now. It is a 70's evinrude 115hp v4. Last year I took the boat out of the water for remodeling. When i took the boat out, i ran the engine dry for storage and haven't started it in about a year. It was hand turned once about 10 months ago but now that i'm done with the remodel i went to check to motor before putting it back on. The fly wheel is super stiff to turn. I can barely budge it by levering, and the starter can only move it about a half an inch each try... i don't have a clue what could be the issue except rust in the head or lower unit, but it ran great before i stored it. could it be the lower unit? are there any tests i can do before serious intrusion?
  #2
Old July 31st, 2009, 06:52 PM
kenmyfam's Avatar
kenmyfam kenmyfam is online now
Default Re: Evinrude 115hp 70's, very stiff flywheel can't turn by hand
Whip the plugs out, spray some oil in there, leave the plugs out for a while and try again.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #3
Old July 31st, 2009, 06:54 PM
Eshaw150 Eshaw150 is offline
Quote:
agreed
__________________
SaltWater Is A B^^^h
89 Travaler 20ft cc 1998 dt140 efi
86 Perferction BassCraft 1975 Merc 20hp Thunderbolt
  #4
Old July 31st, 2009, 11:12 PM
tx1961whaler tx1961whaler is offline
It's not a good idea to run a multi-carbed motor out of gas. One carb will run out of fuel before the other, and those cylinders will run dry for quite a bit. I've done it on single carbs for years, but I shut them down before they completely run out.
If the oil soaking and gentle rocking of the flywheel do loosen it, then take off the lower end first to make sure that isn't locked up.
  #5
Old July 31st, 2009, 11:55 PM
Solittle Solittle is offline
Take the plugs out, tilt the engine up as far as it will go and put a few tablespoons of Marvel Mystery oil in each cylinder. Let it soak for a day or so and then try to turn it over. Use a socket wrench on the flywheel nut if you have to.
You should be able to free it up with no damage. The binding up is usually caused by lite surface rust in the cylinders. Whan free and you get it running the crud will blow out.
  #6
Old August 1st, 2009, 12:16 AM
But do not mix marvel with the gas as it wqill cause running isseus
__________________
  #7
Old August 1st, 2009, 12:32 AM
thank you all for the advice... however, i pulled the carbs and noticed a corrosion stream leading from the fuel jets into the block as if there was water in the bowls or something and it got tilted somehow to bleed back into the engine... I'm kinda thinking the main breaing my be corroded now too... looks like i'm just gonn ahve to piece it out. thank you all for the advice though! ... you live and you learn haha
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
70 hp Evinrude flywheel won't turn bonesc21 Johnson & Evinrude Outboards 18 July 29th, 2009 01:47 PM
starter will not turn flywheel on 35hp evinrude chaseiniowa Johnson & Evinrude Outboards 6 February 23rd, 2009 05:07 AM
96 Seadoo SPX 717 won't turn by hand rmrakt PWC (Jetskis, Waverunners, etc.) 6 July 27th, 2006 06:36 PM
99 225 mercury, can turn flywheel one turn then it stops HELP! jsmith55 Mercury & Mariner Outboards 5 April 29th, 2003 08:24 AM
1973 Evinrude 115hp frozen Flywheel Gazdzik Johnson & Evinrude Outboards 1 July 20th, 2002 10:03 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
