My 1991 Bayliner runs at 150
U28ac12
Im having a problem keeping my Mercurser 3.0l running under 150 and stalking out?......any suggestions before i just give up and take in for repairs?
mkast
Re: My 1991 Bayliner runs at 150
Miles per hour?
Don S
Wow, a less than a 150 mph stalking 3.0L. I've heard of em. Just didn't know of anyone with one :eek: :p :p :rolleyes:
I know 150 isn't speed, but was it rpm? Temp? and I assume it's stalling.
Assuming rpm and it stalls below 750 may just need a full tuneup.
But untill you explain some things and give details of year etc. don't expect much help.
26aftcab454
150 = 1500RPM
stalking= stalling
everybody has to start somewhere-
visually check plgs-,wires, ignition- anything look worn out or broke/ unpluged ?
look for rope / fishing line wrapped around prop ?
make sure fuel & filter are good.
check oil level-does it look milky or clean?
other than that ask around for good shop to take it to.
good luck to you-joe
mkast
A visual inspection will confirm the presents of these items, it won't confirm serviceability.
lowkee
My 3.0L won't go under 150mph.. retreiving it is sheer terror :eek:
"Honey, you start driving away with the trailer and I'll jump the ramp!" :)
