Re: 1971 Mercury 50Hp 500 Trolling and pumping Bulb
Hi Brett,
You may have the wrong pump kit in the motor. Merc made several different valves for their pumps. The difference being the spring strength on the check valves. if you have to original one check to see if the new ones are the same.
If you have a vacuum gauge you should have 1 lb of vacuum on the tank side of the pump.
Your 4 lb ele pump will work fine for your engine.
__________________
This is free internet advice.
Have Fun,
corm
