Greetings
I need some help I just purchased a bass boat with with the above listed motor and upon my second trip to the lake I ran about 1/2 mile up lake and motor ran fine I sat down to go under a bridge and started to get back on plane and the solid alarm came on I shut the engine down because it scared me I let it set for about thirty minutes and turned the switch on and it was no longer alarming is this a temp related problem since it went away or does anyone have any idea what it could be the tech wants to change water pump and pump housing .He said it did not alarm long enough to log a code in on board computer does any one have any ideas also I think when the alarm came on the motor went into what they call rpm reduction mode does that make any sense
