I bought a used 1997 Seadoo Speedster. It has two Rotax engines. I have a broken throttle cable and need to replace it. The Seadoo manual does not cover this but has lots of adjustments shown. When replacing the cable do I need to: synchronize the carbs, adjust the acceleration pump, adjust the oil injection pump??? As I stated the procedure for actually replacing the cable is not in the book so I am not sure which of these adjustments need to be done, if any.
Thanks for any help,
Kevin
Kevin
