reelfishin
- Mar 19, 2007
- 3,043
I picked up a super clean remote only Merc 25hp yesterday.
It's a near mint, mid to late 80's motor with perfect compression.
The motor runs great, starts with just a tap of the starter and I was able to test run it in the water on the boat it came from.
The problem is that it's a long shaft remote only motor and I need a short shaft tiller motor. The price was too right to pass on so I grabbed it, my thinking is that I can make up a jack plate for it and either add a tiller or add a side console to the boat.
There are no numbers on the motor, there's a place where a tag could have been, but it's not there. It looks to have had a new motor bracket installed recently. It's new enough to have a one piece fiberglass cover.
How many years could be potential donor motors to find a good used tiller set up? Converting this to a tiller would be the simplest solution since I'd like to still be able to swap between this and my 9.9 hp tiller for lake use here.
Or, should I just keep looking for a short shaft tiller motor?
(I've been looking for a affordable 25 hp electric start short shaft tiller for over a year with no luck).
