I have a 1965 evinrude 9.5, motor runs great first pull start. I have some questions though
I know this is subjective, but I have a 1957 Lonestar 16 foot closed bow aluminum boat. With a occupant load of around 500lbs. The slowest I can get the motor to troll is 2 mph, after that it wants to bog out and die. The boat seems to be big enough that I should get slower speeds but I really dont know I am new to boats. I can obtain 8-9 mph with the same load at wide open throttle if that is needed as a reference.
The throttle will kill the motor if I slow it too much is this correct or should the kill button be the means of killing the motor,
Here is my question, does it sound like the throttle linkage is out of adjustment?
Is there a way to slow down the idle and have it run good ?
I have already adjusted the low speed idle mix and that has helped but I couldn't get much slower with it adjusted, it just started easier.......
any advice would be greatly appreciated
