Eriespider
- Oct 24, 2008
- 5
I have a 1993 merc 90 hp, 3 cylinders. I have owned it since 1997 and never had any problems with it. I troll a lot, 6-8 hours a day, about 10 times a year. Lately it just will not idle and I have to move throttle forward every time I start it. I changed the plugs which were loaded up and this helped, but after 3 hours of trolling it would not idle again. I took it to the ramp and sprayed a whole can of engine cleaner in the carbs and waited 12 hours and went back to the ramp to run it out. (Followed can directions). I then changed the plugs again and went to the lake to adjust the mixture on the carbs. It started good and idled. After warm-up, I started on the number 1 carb and rotated screw with spring clockwise until I wanted it to choke. Well I got too excited and rotated it all the way in until screw stopped and nothing happened to the engine and I lost track of turns also. The engine was still running. So I backed it out 1.5 turns (just guessing) and thought I would start on the middle carb. This carb did like it was supposed to and started to choke, so I rotated it 1/4 turn counter clockwise. I can't remember what happened next but it seemed I just lost all previously set positions on carbs, so I just set them all to 1.5 turns.
This setting seemed to work ok as I tested acceleration and Idle. I then lowered the idle speed because I was over 3.0 MPH (GPS) at idle in gear. I put the tack on the top cylinder and could not get the engine to go lower than 1200 and continue to run with out cutting out. I got it to 2.5 MPH. I played with the mixture screws backing them all out to 1.75 and tried it again. It got a little better, but no where near the 700-800 rpm idle speed in gear against water that manual called for. Could not get tach down to 1000
Questions - Why wouldn't the number 1 cylinder choke out? How can I get this engine to idle slower according to manual 7-800 rpm?s? What testing procedures should I do to fix this...Easy to more difficult? I was thinking about doing all the resinking carbs, timing, timing advance etc tests in the manual except I don't have the Timing gauge to find TDC and then 2 degrees off. Any other procedures that can do this? My last resort is to take all the carbs apart and clean!
