Greetings all, I'm new to the forum.
This is my first boat its is a 1986 Renken Bowrider with a 2.5 Mercruiser I/O. I have a very limited knowledge about boats and a decent knowledge about engines.
A couple of weeks ago out on the water the boat was running fairly well. I was running about 2600-3000 rpms crusing along when the boat died instantly. Still would turn over but no fire at all.
Yesterday I pulled the fuel line and there is sufficent fuel getting to the carb. I also dumped fuel directly into the carburetor and still no fire.
I then turned to the coil. I unhooked all wires from it. A resistance test from the two outer poles shows 1.1-1.4 ohms resistance. I ready online that a typical coil should read .75-.81 ohms. I then checked from one of the outer poles to the middle contact where the coil wire goes (does it matter which pole u test from?) I found a resistance of 7k ohms. I read online that 10k-11k ohms is typical.
Is this enough data to determine the coil is the culpret!
PLEASE help me get back out on the water
