Hub Size Difference
Boss Hawg
Is there any noticeable or strenght difference in useing a 13x19 instead of a 14x19? The 14x19 was doing great but it got trashed & i found a deal on a 13x19 & money is a issue , i know what the seller will say :rolleyes::(
Re: Hub Size Difference
Ayuh,... Itwould be Nice if you mentioned just What you're workin' on,..??
If it's a Merc... The 13" is for an Mid-sized Outboard,+ the 14" is for an Outdrive, or Large gearcase outboard..
The actual barrel of the prop is smaller on the 13",+ it will ventilate Badly...
Boss Hawg
Dang, i'm sorry :redface:
It's a 1987 70hp Johnson - I'm taking up space anyway :( I'd have sworn i replaced my original (that came with used boat) with a 14x19 but what i had was a 13x19 so i bought the mentioned 13x19 to use & am going to have the one i wrecked repaired for a spare -
I think i'm just getting old :(
I appreciate your time :)
