  #1
Old July 29th, 2009, 07:08 PM
canyonrider canyonrider is offline
Default What size motor should a 22 pontoon have?
What is a decent engine for a 22 foot 2 tube pontoon boat?
  #2
Old July 29th, 2009, 11:36 PM
Mike722's Avatar
Mike722 Mike722 is offline
Default Re: What size motor should a 22 pontoon have?
You should have a plate that list Max Hp rating. Mine is 75 or 90 but I have a 40hp because of price and I don't pull anyone. 40hp is fast enough on our lake. The one neighbor has a 24 footer with a 25hp and the other has a 115hp.
The short answer is no more then the max rating and the rest depends on what you want to do with the pontoon.
  #3
Old August 17th, 2009, 11:34 PM
New Tooner New Tooner is offline
Smile Re: What size motor should a 22 pontoon have?
Has to have a name plate with max hp. The final determination is you.
Size of lake and / or roughness is a good way to look at it (wherever you boat). Sometimes there are HP limits. It's important to size an engine based on preferences. What will you be happy cruising at? Will the need for speed get you too?
Need extra hp for higher cruising speeds (gas usage, wear and tear). You don't want to run WOT no matter what size). I have a 90 hp, 21' that gets me 30 mph on smooth water (unloaded). That is the max on the nameplate.
I'm guessing you'd be able to hang more than 90.
  #4
Old August 18th, 2009, 05:36 AM
5150abf's Avatar
5150abf 5150abf is offline
What do you want to do with it?
If you are going to pull askier or tube you need a bigger engine than you would to just putter around the lake but again you canonly go as big as your rating plate says.
__________________
GO IRISH!!!!
  #5
Old August 22nd, 2009, 12:59 PM
martys's Avatar
martys martys is offline
Thumbs up Re: What size motor should a 22 pontoon have?
I have a Premier 22.5, Legend RE, Triple Toon Ski Package with with a 150 E-TEC. If you are pulling tubes or skiers, this is a nice set-up. Top speed is low forties while cruising between 25 to 30 is a comfortable ride, even in choppy water.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pontoon Trolling Motor Size VaGent Pontoons 5 April 26th, 2009 08:20 PM
Pontoon engine size? gtownky Pontoons 8 September 17th, 2008 11:56 PM
Pontoon Engine Size VaGent Pontoons 15 September 17th, 2008 06:15 PM
prop size for pontoon KennyA Prop Questions and Topics 1 June 18th, 2006 04:49 AM
What size motor for pontoon sunedog Non-Repair Outboard Discussions 4 August 12th, 2004 04:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
