backbaybill
- Jul 31, 2008
- 7
hi, i have a 92 30 hp evinrude. i just did the water pump and now i have a problem. i did it just like the manule said. everything went fine put it in the barrel and pumped water like a champ. used the boat and came home put the ears on to flush it and as soon as i turned on the hose i had water comeing out of the top fill plug. bad fill plug washer but, how is the water getting into the lower unit through the water pump. did a seal fail?
