Bimini Male Snap Repair on Windows from corrosion
night-watch
Really could use some assistance. Corrosion has overtaken my snaps to the windshield. The oxidation has corroded the male snaps and now I have to replace them. Need some ideas. Can I rivet them on? I tried 5200 but it is spongy and flexes too much.
Any ideas for reducing the oxidation on the aluminum would be good as well. I will be taking a wire brush and vinegar and water to it in an attempt to reduce any further damage. Thank you all in advance.
Re: Bimini Male Snap Repair on Windows from corrosion
Ayuh,... Pop-rivets or screws are the Norm...
Bob_VT
ALUMINUM pop rivets only. ..... if you use tiny screws they need to be stainless steel. If you are wire brushing the aluminum you need to use a stainless brush of you will set the frame up to rot away with a galvanic corrosion reaction. As a good measure coat the snaps where they touch the window frame with a dab of 5200. Most snaps are chromed steel.
night-watch
Do I drill out the old snaps? I purchased some never dull for the aluminum. Thanks for your replys.
capt-pete
Call a local shoe repair shop. See if they can put them on for you. They use snaps on everything from jackets to purses, and can put them on for you at a very reasonable price.
night-watch
Thanks for the ideas, got the rivet tool, some 1/8 inch rivets, and its good to go. Now just have to get rid of that corrosion, 5200 the area and let it rip.
