Re: fuel tank
Curt, There is an epoxy product that you can mix up and dump into a empty tank, to seal leaks. I have never used it, however. if you have any oil in he tank, I would doubt it would work. Also, I would think the tank would need to be bone dry.
Can you cut the tank into pieces to remove it, and install a replacemnt tank somewhere else in the boat?
