Been reading quite a bit here today. I have an 88 Renken 3.0 Merc. At the end of last season, the trim wouldnt go down when bringing the boat it. We figured it was just a solenoid so we left it until the season started. Ooof
My trim unit looks kinda like this:
The up/down trim clicks. I attempted to jumper both solenoids, nothing. I took off the trim motor from the pump. When I hotwire the motor, it spins both ways. That leads me to believe there is something wrong with the pump. Any other ideas?
What is the best was to disassemble the pump? I havnt disconnected either of the fluid lines, will they leak if I taken them off the resoviour?
What releases the pump from the resoviour?
Also, when I took off the motor, it was all gunked up. Is that connection supposed to be packed with grease?
Thanks all,
Jason
Thanks all,
Jason
