I have a 1992 - 1993 Force 120 outboard. Motor runs great. Just this last weekend, when you give the boat full throttle and run down the lake, it blows the main fuse on the side of the motor. I lost, Tachometer, fuel gauge, volt meter, power trim and the ability to start it. If I put a 25 or 30 amp back in it, turn on the ignition, it blows the fuse.
I brought it home on Friday, filed down the electrical cable / ends where connects to the battery terminals, I filed down the terminals as to create a good clean connection. Put a 30 amp in it, turned the key on...perfect, great volt reading; so I thought it was bad connection, corroded terminals. I went back to the lake on Saturday, tilt worked fine, boat cranked up, idled from the dock, then gave it full throttle to run down the lake, and immediately lost instrument panel, tilt, etc... fuse blew again when giving it full power.
I had some extra fuses, put one in it, turned the key on, blew the few immediately. I had to put tin foil around it to get the boat back on trailer and get motor tilted up.
Boat runs great....just blows that fuse on the side / top of engine. Any suggestions? Is 30 amp too small? Thanks for any feedback.
Kevin.
Kevin.
