'82 SuzukiDT40C Flush plug? Huh?
readynow
I have a SuzuliDT40C
I know what the "Oil filler plug" and the "oil drain plug" are for,
but what is the "Flush Plug" for and how is it used?
The manual is VERY vague about this.
ty
deejaycee_2000
Re: '82 SuzukiDT40C Flush plug? Huh?
It is basically to flush the motor with fresh water after use in salt water to prevent salt buildup, but it is much easier to just use the muffs ......
readynow
Thank you Sir.
Does using the muffs clean that area of the motor?
Is it a good idea to use this Flush area now and then?
Thanks again!
deejaycee_2000
With the muffs on the fresh water will rinse out the whole cooling system ... so no need to use the flush plug ... it oes the exact same job ...
