  #1
Old July 28th, 2009, 11:18 AM
Mark42's Avatar
Mark42 Mark42 is offline
Default Found water in forward most section of cuddy
The Cuddy version of the popular 1600's has no flotation foam in the forward bow area like the bow rider version does. When the v birth bed is lifted up, there are storage compartments underneath with no drainage. The one in the very front of the bow collected about 1-2 cups of water. From the water stain, I would say there were probably 3-5 cups total but some has evaporated. Soaked up the remaining water and wiped off the water marks with a rag. Just not sure how the water got in there. In this photo, its under the front triangle piece of the bed.
I checked the bow eye, no sign of leaking there. There are no other through hull fittings in that compartment. It could have leaked in over the winter with snow and ice built up on top of the cuddy. Maybe the hatch?
Lucky for me the factory glassed and gel coated the crap out of these compartments, so the water is not soaking into the plywood. Tje other two compartments are dry as a bone and show no water marks.
Other than doing a full on garden hose test, any one else ever experience this in a cuddy?
__________________
1985 Bayliner 1600 Capri Cuddy, 1965 MFG Niagara Custom. >> MFG Video<<. >> MFG Project<< >>Bayliner Hard Top Project<< >>Bayliner Fuel Tank Project<<
  #2
Old July 29th, 2009, 12:27 PM
Doggonitt's Avatar
Doggonitt Doggonitt is offline
Default Re: Found water in forward most section of cuddy
I had the same problem with our 1986 28.5 Contessa. Only the V berth got water, not the sides. Took a long time to figure. Ours was coming from multiple places though. The biggest area of concern for us, and I have found in our newer Bayliner is the deck to hull joint where the rub rail runs around. Over the years, the screws holding the aluminum rub rail loosen from either being bounced around or from small stress cracks. I was shocked at how many loose screws we had when we pulled off the rubber. The rubber was getting old and had some cracks itself from docking or pilings, so I was going to replace it 1" 3 ply rope. I used "Captain Tolley's Creeping Crack Cure" because it is flexible, and squirted some in every screw opening, then tightened all the screws. "Make sure that ALL is dry before doing that". I also ran the bottle around the whole aluminum rail where it meets the fiberglass. Then I used marine silicone to put the rope on instead of screws. I used a lot. That fixed most of the problem. The other place leaks were coming from was the stanchions. Our kids leaned against the rails all the time, and after years of abuse, tiny stress cracks showed. I wouldn't have thought that it was a problem until I soaked the heck out the two front ones. Sure enough, not even a trickle but enough to feel the wet.
So I used the Capt Tolley's on those also. I know it wasn't the correct way to repair it, but it helped until the right repairs could be made. The other place to check is any hatches. Any leaks there and the water just follows the flow down. Hope this helps.
  #3
Old July 29th, 2009, 02:19 PM
Mark42's Avatar
Thanks for that info. I guess the best thing to do is have someone hose it down while I'm inside.
I'll check the joint behind the rub rail too.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hull ID is nowhere to be found on a 1981 cuddy. rs2k Boat Topics and Questions (not engine topics) 4 May 18th, 2009 11:51 PM
230 sx water in cuddy!!?? bounced czech Boat Topics and Questions (not engine topics) 10 January 29th, 2009 11:48 PM
Mid Section water leak Kellyz2 Johnson & Evinrude Outboards 4 September 5th, 2007 03:02 PM
No water coming out exhaust holes in mid section ba_50 Johnson & Evinrude Outboards 3 November 29th, 2006 07:27 AM
1981 Johnson replaced water pump and now no water and no forward gear. Paul Moore Johnson & Evinrude Outboards 11 April 22nd, 2006 03:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
