Hi, well, thanks to reading a lot of posts and getting a subscription to an online manual (which I am mixed about) I decided to try to replace my impeller (1985 Johnson 30 HP outboard) after noticing a very weak indicator stream.
I was able to remove the lower unit and remove the pump housing. I found some creatures were making a home and I assume they are the reason for the poor water flow (I still need to inspect other areas). I came away with a couple questions I wanted to seek some feedback on if anyone can help.
First, is there anything in particular that should be used to thoroughly clean out debris in the channels around the impeller? Of course I scraped or brushed out what obvious debris (include my little friends). Should I just do my best to flush out with water? I just wanted to make sure there wasn't something else people use or do.
The online manual mentions this when talking about installing the housing - "Lubricate the inside surface of the water pump with light-weight oil." Is this oil like WD-40? And exactly what part are they referring to ? The inside metal ring within the housing that the impeller turns within?
Also, the drive shaft had a bit of rust along the upper portions (above the area of the water pump housing. Is this an issue? Should I just remove the rust? Just wondering if it indicated a problem. (sorry the picture is a little fuzzy)
I attached a couple pictures - thought this post might help others out.
Thanks!
Thanks!
