  #1
Old July 28th, 2009, 02:37 AM
goodtimes goodtimes is offline
Default 1996 Evinrude 50hp E50TLEDS- Shift rod will not move shift dog to reverse position.
Hello,
Just got a boat with a 1996 Evinrude 50hp E50TLEDS. I tried to remove the lower unit to check the impeller. I removed the screw/pin that holds the shift rod from the lower unit insted of the top shaft connection (big mistake). I couldn't get it back to line up for the pin. So...I took the shaft cover out to see how the shaft connects to the shift dog. My model does not have the shifter cradle (0332507) per BRP catalog and I'm not sure how it suppose to connect. I tried the only way I thought possible was on the big shaft with a lip and the pin lined up but it only goes into forward and neutral but not reverse. The engine shifted with no problems before.
Can someone please tell me what I'm doing wrong??? Is there any way the cradle could have gone deeper into the gear housing. Do I need oil in the lower unit for it to shift to reverse? (Was trying w/o oil in lower unit) Does the other retaining screw (0324852) on the lower unit have anything to do with it? That was removed also. What does that screw retain anyways?
Thank You
  #2
Old July 28th, 2009, 05:57 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1996 Evinrude 50hp E50TLEDS- Shift rod will not move shaft dog to reverse positio
you can see diagrams here. http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 28th, 2009, 12:46 PM
thanks tashasdaddy, I already looked at the BRP diagrams. My model did NOT have the shifter cradle. Any thoughts on how mymodel connects to the shifter dog?
  #4
Old July 29th, 2009, 02:15 AM
Default Re: 1996 Evinrude 50hp E50TLEDS- Shift rod will not move shift dog to reverse positio
Got the manual and took apart the LU. The shifter cradle was stuck in there. Now it works fine but I can't find the correct shift shaft lenght in the manual. Does anyone know what it should be? The Seloc Manual was NOT helpful at all, had only a paragraph about my LU.
  #5
Old July 29th, 2009, 07:00 AM
21 15/16 inches
__________________
FLORIDA GATORS
TEBOW Country
  #6
Old July 29th, 2009, 06:43 PM
Thanks tashasdaddy,
Everything works good now.
  #7
Old July 29th, 2009, 08:13 PM
wilde1j wilde1j is offline
The LU should have cast into it next to the Phillips cradle pivot "DO NOT TOUCH"!
__________________
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Putting drive unit back on.... shift shaft position? bluemarshboater Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 14 July 22nd, 2009 11:27 AM
1969 Merc 1000 Shift Shaft Position NJCinMN Mercury & Mariner Outboards 2 July 14th, 2009 11:29 AM
How Fast Should 50hp Evinrude Lark Move My Pontoon Boat mirage5058 Johnson & Evinrude Outboards 10 July 12th, 2009 12:20 AM
Mercury 50hp shift shaft and cam position cwglo1 Mercury & Mariner Outboards 2 December 17th, 2007 08:33 PM
merc 500 shift shaft trouble,now I lost my reverse. rolmops Mercury & Mariner Outboards 6 August 9th, 2004 01:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
