  #1
Old July 28th, 2009, 12:47 AM
99yam40 99yam40 is offline
Default Yamaha C40TLRX carburetor kit missing o-rings
Has anyone else found out that the Yamaha carburetor kits do not contain the o-rings that go on the inlet seats? It seems strange that they are not included with the new needle,seats, floats and other o-rings and gaskets . The local Yamaha dealer told me you just have to pull them off the old seats and put them on the new ones. I originally thought that the design was changed and did not require them anymore, but even the mechanic told me to use the old ones and they do not even have them in stock. will have to order them if I want them.
Also when I pulled the carbs back off and disassembled them I found the rubber plugs in all 3 carbs in the bottom of the bowls, not in the hole covering the idle jets where I had installed them.
Has anyone had a problem with this happening to them and what would cause this to happen? A back fire? I know I fully seated them and I have been chasing a problem with idling and a high speed miss. Hopefully this will help out. I will find out tomorrow after I reinstall and test.
  #2
Old July 28th, 2009, 07:28 PM
rodbolt rodbolt is offline
Default Re: Yamaha C40TLRX carburetor kit missing o-rings
do I find it strange? yep.
but its kinda normal.
even some of the V motor carb kits dont contain the gasket for the plug that allows access to the pilot fuel jet.
they do include a spare fuel bowl to body screw though.
I dont like reusing that oring, I have but dont like it, I usually have them in stock.
sometimes stock gets depleted faster than replenished though.
  #3
Old July 28th, 2009, 08:15 PM
Default Rodbolt, motor still cutting out at WOT
This is really getting strange. my motor still has the high speed cutout or miss, but when I take the cowling and silencer off of the front of the carbs it runs fine WOT, no miss or cut out. when I install the cowling and leave the silencer off it runs good but I can still hear and feel it miss every once and awhile. Reinstall the silencer and it cuts out a lot at WOT. Is it possible that there is a air bleed or orifice that is plugged that I keep missing I have been through the carbs 5 or 6 times in the last month looking for something causing the problems or maybe the jets have been opened up by someone(I am the 3rd owner ) This thing just seems to be running rich if removing the restrictions from the front of carbs makes it run better.
What could be causing these type of symptoms?
  #4
Old July 29th, 2009, 06:31 PM
I would also like to find out what kind of a signal does the tach receive from this motor. Voltage , etc, and could it be read by a Digital VOM on a hz setting to reprsent the RPM?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
C40TLRX stumbling or cutting out 99yam40 Yamaha & Suzuki Outboards 3 June 22nd, 2009 03:02 PM
C40TLRX yamaha timing problem 99yam40 Yamaha & Suzuki Outboards 3 June 15th, 2009 08:20 PM
Yamaha T-50 oil in gas, rings ok??? Bob_T Yamaha & Suzuki Outboards 7 June 17th, 2004 09:58 AM
Yamaha T-50 oil in gas, rings ok??? Bob_T Non-Repair Outboard Discussions 3 June 16th, 2004 04:05 AM
yamaha putting in some rings.. REEL-BREAK Yamaha & Suzuki Outboards 3 May 28th, 2003 02:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
