slice-of-life
- Jul 5, 2009
- 6
Hey folks new user here,glad to see this forum compared to the days when i used to experiment with my old chrysler and learn the old way!!
I have a 1994 force 120. Purchased the boat used, motor idled great everything ran fine. However, before i got to change out the old gas (dont know how long the boat sat, at least a year), during idle in the driveway it coughed, sputtered and died. Could not restart without opening up the butterflies big time.
I have checked compression, good all cyl between 160-170. Spark seems good, all fuel lines changed, from tank to motor, no disconnect, new inline filter and bulb. New fuel diaphragm, new vac lines, carbs taken apart and cleaned. I did notice the lock nut on the timing (top of tower shaft was loose). adjustment doesnt help. took it out yesterday, had fuel treatment, runs great top end, nice and smooth, but i cant get it to start without butterflies open and lots of fuel. wont idle. when running at full throttle, covering bottom carb chokes motor and dies, covering top one does not.
ANY IDEAS???????????? totally stuck!! Reeds? carbs? stator?
MOtor has red stator on it
