roscottjr
- Jun 10, 2006
- 330
I have a 1993 Johnson 48hp Outboard model J48ESLETE. We were at the lake and suddenly a clicking sound began coming from the engine. I put the engine in neutral and idled it up a little and there was no sound. I put it in reverse and still no sound. I then put it in forward and there was the sound. From what I can tell, it is not the engine and it only does it under load in forward gear. We were wuite a bit away from camp so we tried to make it but the clicking sound got worse so we shut off the engine and used the trolling motor to get back to camp. I got the boat on the trailor and out of the lake and then started the engine again. I put the engine in forward and no clicking so I am sure now it only does it when under load. I checked the gear oil before going to the lake and it was full. It was still full after this happened. I also checked the prop thinking maybe the shear pin come out or we were about to loose a prop and still found nothing wrong. I am pretty sure it is in the gearcase or maybe between the gearcase and engine but Im not sure yet what it may be. Does anyone have any ideas what I should look for or if there is something I have missed? I am hopeing to find it to be something simple but from the way it sounds Im pretty sure the gearcase is going to have to come apart. Thanks in advance for any help.
Robert
Robert
