  #1
Old July 27th, 2009, 09:58 PM
ddodgeman03 ddodgeman03 is offline
Default evinrude 115 powerhead interchangability
I have a 1992 115 Evinrude that I lost my #4 cylinder on. Pulled the head and piston was beat to heck plug was as well. Any ideas on what could have went through cylinder so i can make sure this doesnt happen again? I was suspecting a broken ring. Second question is what year powerheads are interchangable with mine. If I use a different year will there be any other considerations ( ie: compression ratio, other connections and compatibilites). Also what other options would I have as far as different v-4 powerheads in different horsepower ratings off different year models. What about off of a Johnson?Any help here would be greatly appreciated. Thanks.
  #2
Old July 27th, 2009, 10:07 PM
ryendube ryendube is offline
Default Re: evinrude 115 powerhead interchangability
Quote:
Originally Posted by ddodgeman03 View Post
I have a 1992 115 Evinrude that I lost my #4 cylinder on. Pulled the head and piston was beat to heck plug was as well. Any ideas on what could have went through cylinder so i can make sure this doesnt happen again? I was suspecting a broken ring. Second question is what year powerheads are interchangable with mine. If I use a different year will there be any other considerations ( ie: compression ratio, other connections and compatibilites). Any help here would be greatly appreciated. Thanks.
you would see shrapenal or a missing ring... you recently change your plugs?you sure the right plug was used? ie to long of a reach? smashed up against piston?
  #3
Old July 27th, 2009, 10:12 PM
Plugs were not changed recently and piston was beat up on entire top, not just where it would have hit electrode. i was also wondering if any other size powerheads would work on my motor if so what years and sizes can i use. thanks
  #4
Old August 6th, 2009, 10:20 PM
jdhibbs jdhibbs is offline
Smile Re: evinrude 115 powerhead interchangability
. OMC Johnson and Evinrude are pretty much the same as they are manufactured by OMC OMC is gray, Johnson is white, and Evinrude is blue. I have an OMC 1992 115 and use Johnson and evinrude parts. All parts are listed as OMC on the parts websites. If you have a V4 cross flow engine, life is good as this block was a commonly mass produced block and produced for many years. Also, there are many places that sell short blocks for this engine. I just finished rebuilding mine and it runs as good as new.
hope this helps
  #5
Old August 7th, 2009, 07:02 AM
emdsapmgr emdsapmgr is offline
Not unusual for a crossflow to throw a ring. If the rings get carboned up, they will overheat, then crack and the fragments will rattle around in the combustion chamber till they break up, then exit the exhaust. Using a carbon guard treatment periodically will extend the life of these engines, running on today's poor quality fuels.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Johnson 25hp Powerhead Interchangability meathanger Johnson & Evinrude Outboards 5 November 6th, 2008 12:26 AM
'60/'67 40hp Evinrude Interchangability doug24_98 Johnson & Evinrude Outboards 2 October 14th, 2008 04:28 PM
Powerhead interchangability on 1956 Johnson 30hp lower unit PatrickMFrank Johnson & Evinrude Outboards 11 May 1st, 2008 05:00 PM
powerhead interchangability Roman ski's Johnson & Evinrude Outboards 4 September 3rd, 2007 05:15 PM
'81 evinrude 70hp gear interchangability mikesjohnson Johnson & Evinrude Outboards 1 May 14th, 2007 12:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
