  #1
Old July 27th, 2009, 06:18 PM
rosemb rosemb is offline
Default Evinrude 70 2 Stroke (1980??)
Hi,
I have a 70hp 2 stork Evinrude outboard. Just checked the plugs and they need replacing,. What is the recommended replacement spark plug type and gap setting? I notice that the bottom plug diameter is bigger than the upper two spark plugs
  #2
Old July 27th, 2009, 06:36 PM
bob johnson bob johnson is offline
Default Re: Evinrude 70 2 Stroke (1980??)
they should all be the same size is my guess......
it is highly likely that the lower cylinder had its plud threads stripped out and they went ahead and tapped for a larger spark plug.
I am pretty sure the plug that the motor normally uses is a VERY common plug
I dont remember it right now..
ok looked it up...OMC 1989 manual for a 70 hp
recommended QL77JC4
alternate L77JC4
sustained high speed QL78V
alternate high speed L78V
good luck
if you got as larger size plug thread in one hole...you got to make a choice of a plug that is about the same heat range as the ones you will use in the other two cylinders.. ahhh outboard motors!!!
bob
  #3
Old July 27th, 2009, 06:55 PM
Thanks for the reply, will try to find an equivalent plug for the lower cylinder
  #4
Old July 27th, 2009, 07:33 PM
Hi
The bottom cylinder head spark plug boar has been increased to a next larger size due to someone stripping the thread, any recommendations on spark plug type and gap size for the bottom cylinder?
  #5
Old July 27th, 2009, 08:52 PM
wilde1j wilde1j is offline
Remove the head and take it to a machine shop to get a correct size Helicoil installed. They don't make the "right" plug in different thread sizes. If the head is too crapped up, get a used one from one of the many OB parts recyclers such as tcoutboards.com, etc.
__________________
Jim
  #6
Old July 27th, 2009, 10:40 PM
you MIGHT.....be able to find an adapter which will have males threads the size of the larger spark plug... and femal threads the size of the plug you should beusing...
as we all should know taking a head moff might lead to even bigger problems than a odd ball spark plug..
it isnt feasable that all the head bolts will come off with out at least ONE breaking....the motor is at least 25 years old or there about
if it were me, Id ask and ask till I found a temperature range similar to the one that should be used.. and just go with that...as long as the plug does not protrude too deep into the cylinder !!
good luck
bob
  #7
Old July 27th, 2009, 11:25 PM
I don't agree about removing the head. If you do it right, there's absolutely no reason to break a head bolt.
__________________
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1980 Mercury Outboard, 50HP 2-stroke, low compression, help! jpriesjr0883 Mercury & Mariner Outboards 6 June 28th, 2009 01:24 AM
1980 60 hp evinrude junky Johnson & Evinrude Outboards 7 June 11th, 2009 12:19 AM
1980 Evinrude 150 hot at WOT Striper68 Johnson & Evinrude Outboards 6 October 23rd, 2007 06:23 AM
1980 115 hp evinrude cbster Johnson & Evinrude Outboards 0 August 12th, 2007 04:31 PM
1980 Evinrude 85 HP mljfl@twcny.rr.com Johnson & Evinrude Outboards 3 March 10th, 2006 05:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
