  #1
Old July 27th, 2009, 11:26 AM
DukesFin's Avatar
DukesFin DukesFin is offline
Default 1990 Yamaha 150 ETXD Low Speed Temp Alarm...
I (SOMETIMES) get an overheat alarm when trolling. This only happens sometimes. I shut the motor down and sometimes I can fire it right back up and the alarm is gone, other times, I have to let it sit for 15-30 minutes and let it cool off before the alarm stops.
Where do I begin?
The first time this happened (about a month ago), I immediately replaced the thermostats because they were cheap and had no idea when the last time the PO did it. I thought this solved the problem, but it's come back up again...
Again, this is at low speed/trolling/idle only. On plane, I never get the alarm. Also, the water pump is new!
Thanks in advance for the help in troubleshooting!
__________________
1990 Cabo 204 Centercon Yamaha 150
  #2
Old July 27th, 2009, 03:38 PM
svilla svilla is offline
Default Re: 1990 Yamaha 150 ETXD Low Speed Temp Alarm...
There is also a low speed valve in the cooling system too. I have a 1997 150 2 stroke and it was very easy to get to mine. Any how mine had lots of old salt build up and did not close correctly. So I just removed the cup, spring, and plastic poppet, and cleaned all the parts real good and also the mounting surface for the poppet and that did the trick.
http://www.boats.net/parts/search/Ya...ASE/parts.html
you are looking at parts 49 - 53 all you need to do is remove and clean these parts, replace any that are bad.
  #3
Old July 27th, 2009, 04:15 PM
DukesFin's Avatar
I thought it would be either the PRV (what you mention) or the temp senders.
I might go ahead and replace all of it since I have NO idea when the last time it was cleaned/done!
Thx
__________________
  #4
Old July 27th, 2009, 10:38 PM
Yeah it only took me like 15 min to remove, clean, and replace mine. Lets us know how it turns out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 Yamaha 150 ETXD Idle Too High DukesFin Yamaha & Suzuki Outboards 3 March 26th, 2009 01:38 PM
1990 Yamaha 150 ETXD Water Pump jcotton Yamaha & Suzuki Outboards 5 February 17th, 2008 10:13 PM
2001 135 Optimax temp. alarm @ low speed jeh2337 Mercury & Mariner Outboards 9 April 24th, 2006 10:32 AM
1990 225 ETXD: Prime Start sadcorp@aol.com Yamaha & Suzuki Outboards 4 October 2nd, 2005 07:42 AM
1990 Yamaha 200 ETXD Idle Problem ICU Yamaha & Suzuki Outboards 3 January 5th, 2004 02:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
