05superglide95hp
- Jul 4, 2009
- 5
I had it running last year after alot of screwing around. It ran fine and could start it all day. Next day nothing again. So I get back into it, and there's no spark again. I have a book and have tested the stator, replaced trigger assembly due to brittle wire, and coils. All checked out good. The book says if all that is good replace the switchbox. Is there any tests that can be ran on it to determine if it's bad? Or is that usually the way it goes with a 25 year old motor? Is the switchbox going bad that common of a thing? I can't think of anything else to test. I cleaned the carbs, rebuilt the fuel pump, had to buy new gas tank since there wasn't one. Don't know what else to try. Just hoping for a "did you try this", before I start spending more money.
