Re: condensation inside carb?
no worries, that's what we're here for. weather/air temp/air quality is constantly changing everywhere. never assume that just because it hasn't happened before, that it can't happen. a little trick, especially if boat sits covered for a bit, go to hardware store and pick up one or two of the DRI-Z AIR things. if you're canvas cover doesn't leak, leave engine cover off while boat is covered, put one of the DRI-Z towards bow, other stern. otherwise if cover needs to be over engine, put one of them under the cover of motor, or under seat next to motor, somewhere where it can draw the moisture out of the engine area. these things work awesome to help control moisture and condensation.
