  #1
Old July 26th, 2009, 09:08 PM
tnbiker tnbiker is offline
Unhappy 2005 Mercury 50hp 4-stroke - Reverse Polarity
Help. I have a 2005 Mercury 50 hp 4 stroke and have reversed the polarity when hooking up the battery.
I tried to start it with the reversed polarity but only once. Nothing happened so I stopped. No smoking, no fried wires, no electrical burn smells.
I hooked the battery back up correctly and the battery reads approx 12+ volts with my multimeter so I feel confident the battery is still good. However, the motor will not start. The instrument panel/lights works and warning beep sounds. The trim motor works. However, the starter will not spin the motor.
All 4 fuses that I could locate in a single block look good (2-20a, 1-25a & 1-5a). I can bypass the starter solenoid and the start motor spins but the motor will not start so I suspect something in the firing process is screwed also.
Any ideas on where I can start on trouble-shooting this? I'm guessing the solenoid will need to be replaced to at least get the starter motor working again. From there what would you recommend trying next?
Could there be more fuses or fusible links that I'm overlooking than just the four mentioned. Is there any type of resets (like a breaker) I need to check before testing/replacing parts?
  #2
Old September 27th, 2009, 06:48 AM
miguelito miguelito is offline
Default Re: 2005 Mercury 50hp 4-stroke - Reverse Polarity
I have the same problem. 2008 Suzuki 40 hp 4 Stroke and I reversed the polarty. I needed to replace the fuse to the marine radio.
Everything works expect the ignition and power tilt are dead. I am no longer hearing a beep when the key is turned on.
Any suggestions?
  #3
Old September 27th, 2009, 10:34 AM
Silvertip Silvertip is offline
There is a fuse at the engine. Here is what it looks like on a 75hp Merc triple. Most engines have a fuse(s) but may not be in the same exact area or look the same. It is the plastic holder with the word "Fuse" by it at the top of the picture.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Reverse Polarity rnl Electrics, Electronics and Trolling Motors 5 May 27th, 2009 12:53 PM
2005 50hp 4-stroke Merc alarm keeps coming on Harveycats Mercury & Mariner Outboards 0 May 24th, 2008 02:48 PM
Inverted 2005 Yamaha 4 stroke 50hp csotherland Yamaha & Suzuki Outboards 2 March 6th, 2008 12:04 AM
2005 Merc 50hp 2 stroke idle problem dobester Mercury & Mariner Outboards 0 June 17th, 2007 08:27 PM
Reverse polarity ? Skip 2 Agincourt Johnson & Evinrude Outboards 0 July 30th, 2003 08:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
