Wiboater6181
- Jul 3, 2009
- 8
I have fuel related problem. Motor starts and idles fine. When I take off and get up on plane, it will go about 150 yards and then slowly loose power. I will slow down to about 2000-3000 RPM and bounce around in that RPM range. If I slow to idle again for a minute or so then take off, same thing happens again. If I pump the ball when it start to slow down, it come back to life again for another 150 yards or so. I have replaced the fuel filter and drained and cleaned in the inside of the fuel tank and fule pick up screen. Might this be a fuel pump problem? Do i just start replacing fuel line until its fixed? Looking for options. THanks.
