I need to clean out the carb on my dad's pontoon motor after is sat for 6 mo and now starves for fuel. It runs great at very low speeds, but quickly starves down and dies if you accelerate. It looks like the port nut on the carb barrel is too tight behind the starter to access. Is there a trick here? Do I have to figure out how to remove the starter?( Hope not) I wondered if there was any chemical cleaner one could use instead of a carb removal/cleanout. Any help would be so much appreciated. Sorry about so many questions.
THanks
THanks
