  #1
Old July 25th, 2009, 05:41 PM
adamjr adamjr is offline
Default 1972 Evinrude 125283r cooling question.
I have a cooling system question about my 72 125 HP 'Rude 125283R
I rebuilt the water pump and re-installed the lower unit. I hooked up the ear muffs and turned the hose on full blast and ran the engine. No water was seen shooting out of the propeller hub so I was thinking it wasn't cooling. I removed the cover for the thermostat housing and took the Vernatherm out. I used a sharpie and marked the push rod. I put the Vernatherm in a glass and I microwaved some water. The water was 140 f on an instant read (the Vernatherm is rated at 105 f). I poured the water into the glass and watched the push rod lift about 3/16th of an inch. Then I chilled some water and filled the glass the rest of the way and the push rod retracted after about a minute. When I was handling the Vernatherm afterward the push rod came out. I put it back in and reassembled the thermostat housing.
After reassembly I ran the motor for a little over 5 minutes. Still nothing coming out of the prop hub that I could see. I removed the two hoses and some water came out of both sides of the thermostat housing but not a lot.
So here are my questions and suppositions:
Is the thermostat maybe just a little too weak to push up the check disk? Am I correct in believing the push rod hould not come out of the Vernatherm? Is it possible the water is exiting but I'm just not seeing it with the water spraying from the ear muffs? I would have expected a gusher.
Thanks in advance.
  #2
Old July 27th, 2009, 11:08 PM
Default Re: 1972 Evinrude 125283r cooling question.
Anyone?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 125283R, Calco trim parts list? adamjr Johnson & Evinrude Outboards 3 July 27th, 2009 11:09 PM
1972 Evinrude 65 hp question splattman2004 Johnson & Evinrude Outboards 7 May 27th, 2009 04:55 PM
1972 Evinrude 6HP cooling problem??? dmiller40 Johnson & Evinrude Outboards 3 April 18th, 2008 10:07 AM
1972 18 HP Evinrude Question msutton58 Johnson & Evinrude Outboards 2 April 9th, 2005 01:17 PM
1972 Evinrude Cooling sdking2000 Johnson & Evinrude Outboards 0 May 16th, 2002 07:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
