I had this problem last season and never found a solution for it. Here's what is happening.
Problem one.
Motor starts fine and idles fine.
I take the boat out from the dock and increase throttle.
Revs increase to 2k for a second or two then they increase to 5k
Motor has no hole shot.
Problem two.
After running down the river for a km or two the motor starts missing or kicking. I lower the revs and it runs fine again for a minute or 2 and then does the miss again and I lower the revs etc.... Eventually I am running the boat at 1500rpm. I at this point cannot increase the revs with out the motor spluttering and kicking. Now if I turn off the motor for 2 minutes and then start again it will run WOT again. During this I have tried squeezing the primer bulb and it does not help.
Problem one.
Problem two.
