I just bought another project boat that has a 1985 140 merc 4cyl. this engine was rebuilt 2 years ago and the boat has only 10-15hrs on the new engine. it has what I will call a Rattle in it. all I can tell is it is not from the topend! pulling the plug wires does nothing to change the noise and it is more noticable on idle then at higher RPM's. when you shut the engine off it changes tone a bit and gives one "more of a clangy" noise just before the engine stops?
the engine does have a slight miss and some hesitation giving it throttle but over all seems to run well once warm.
I know this is not recomended but I had a bottle of STP oil treatment (like Honey) and I added it to see if the noise would change, typically it will change or quit if it is lifters or bearings, this also made no change at all in the noise, (I will change the oil, don't worry)
so I am wondering what other sources of rattle are their in the 140 mercruiser? i would not really call it a knock and by using a screwdriver in your ear I can't pinpoint it at all except you hear nothing from the valve cover. and it sounds more from the rear of the engine.
this engine was totally rebuilt by a local shop with new pistons, rings bearings etc...
