Re: Aerator pump problem
Absolutely right, if you want a steady pick up you'll have to go tru-hull with a strainer pick up for your water. Be aware at planing speed you can force feed a lot of water into your live well. I had a 1 1/2" discharge line off the side on my above deck livewell and could move a lot of water. If you don't want to cut a hole in hull, you can mount a pick up tube just under the keel but if you trailer, make it easily removable. Recirculation is the easiest if you don't have long distances to run and the bait is fairly hearty. The worst thing you can do is have a filter clog up with scales and stop the bubble flow to the bait unless you want to make chum for next trip.
Good luck and safe boating ya'll
