1977 Omc 175hp
nhw1960
I've inherited a 1977 Mirrocraft 21FT that appears to be in great shape. It only has 425 hours on it. The problem I'm finding is that it is periodically spinning/slipping out of gear. Not at any particular RPM...just very random. I cut the throttle and re-engage and it's fine for a while, then it will happen again. Any thoughts??? Thanks
Lyndy
Re: 1977 Omc 175hp
If the drive is a 1977 it should be an electric shift. Since it appears to random I check the 2 wire bundle that exits through the Intermediate Casing and goes down to the Lower Gear Case shorts I should have voltage running through it. Should do it as quickly as possible because if the gearcase disengages and engages right away damage can occur to the Lower Gear Box.
WizeOne
Re: 1977 Omc 175hp
Absolutely DITTO!
