Re: Motor not started for 2 years
1 Pull the plugs and spray PB Blaster in all cylinders.
2 Turn the crank by hand (pull start fly wheel) If it turns all the way around easily you are in good shape to fire it. Fly wheel should turn smoothly. If not get a bore scope and check cylinder walls to see how bad the rust ring is, this will tell you how bad it is and if you need to tear it apart to replace rings and such.
3 hopefully the motor was ran out of gas when it was stored otherwise you may have carb work to do lacquered gas is a big problem, floats, needles, ect. need cleaned, you can smell the gas and it will smell like varnish (Big Problems)
4 If everything checks out replace plugs and see if it will fire.
Good Luck
Just went through this on my Dads 65h Merc She fired and all is well.
