bear_69cuda
- Oct 10, 2008
- 2,109
Morning Gang,
I ordered the new reservoir, bottom screw and o-rings for my trim/tilt pump. Single screw type for 1999 Alpha I gen II drive. Looking at the service manual, they say to remove the hydraulic lines from the pump adapter relieving pressure, then remove the entire assembly before removing the reservoir from the pump adapter/motor. It looks to me like I could possibly just remove the motor, adaptor, and the reservoir with lines connected, remove the single screw holding the reservoir to the adapter, replace reservoir with new o-ring, and screw with new o-ring, without removing hydraulic lines... Anyone do it this way?
