Re: Wiring a switch and isolator
I think if I understand you correctly, yes, but you want the big wires on the switch, not going through the isolator. the isolator is an add on. get the basics, and then add in the isolator.
Lets start with installing the switch so you can use your boat.
Big red from motor. Put that on "feed" for your switch.
Big reds from switch. put one on each of your batteries positive.
Small red from GPS and all other electronics will go to the "Feed" on the switch.
--- note here, you may have a single wire from the front of the boat going to some type of fuse box, add that to the positive.
Big Black from motor. put that on either negative post.
You should have another big black, going between both battery's negatives. (you may have to buy this, or already have this)
Small black from GPS and all other electronics will go to one of the batteries negative terminal.
That should be your basic setup, without the isolator. You should be able to start your boat, and run all electronics with the switch in position 1, 2 or both.
To add the isolator, add a small Red wire from your "Feed" to the common post on your isolator. Add 2 small red wires from your isolator output posts (likely the outside 2) to each battery (i.e. one on left goes to bat1, one on right to bat 2)
That should give you what you want
Some conveniences you may want to consider.
Electricity does not really care which side of the wire you connect (if they are short), so you can use this to your advantage to simplify your battery connections.
You may find it easier to connect the output posts of the isolator to your switch. put them on the input side (marked 1 & 2, or A & B). You have it drawn this way in your diagram. Don't go through the isolator and "feed back to the switch" because that is your starting circuit (i.e. the most power) keep that as simple a circuit as possible. battery to switch to motor is best.
You may find it easier to connect all the grounds to a common "bolt" and have 2 wires(Big ones) going from the bolt to the negatives on the batteries. you don't have it drawn this way.
Note: use at least a 10gauge wire to and from your isolator. when I say Big ones, this should likely be 2 gauge or less (lower numbers = larger wire)
Also. I really like to have at most 2 wires connected to my battery, USGC allows for 4 I believe, but you really start to get bad connections if you have more than 1 or 2. I can get a much better connection using a bolt, or a distribution panel than I can cranking down on my battery. The added benefit, it is easier to remember next spring how to re-install your batteries.
Hope that helps. I have hacked up your diagram a little. hope it helps.
