  #1
Old July 24th, 2009, 12:45 PM
michaelwelborn michaelwelborn is offline
Default 1973 Evinrude 65 Water in Cylinder
Have a 1973 Evinrude 65 Hp and I am getting water in the number 3 cylinder. Had this problem 2 years ago. I replaced the Head Gasket last spring and it ran great all last summer. Have had it out 5 or 6 times this year and it ran great also. Last time out on the water it would take forever to get up to max rpm at WOT. Once it did it ran ok but had a small rattle in the engine and was not performing as good as usual. When I got home i pulled the plugs and the number 3 was wet. I did a compression check and Have #1-110psi #2-105psi #3-90psi Could it be the head gasket again and if so what would cause it to go bad so quickly? Thanks for the help.
  #2
Old July 24th, 2009, 01:02 PM
petryshyn petryshyn is offline
Default Re: 1973 Evinrude 65 Water in Cylinder
HI
Only easy way to tell is to pull the head and inspect. When you replaced the head gasket, did you:
-check the head for straightness with straight edge
-resurface head on rubbing block or flat surface
-torque head to specs
-torque head in proper bolt sequence
__________________
Alias "schematic"
  #3
Old July 25th, 2009, 12:09 PM
Did all these things but resurface head. Guess I can pull the Head and have a look. thanks for the info.
  #4
Old July 26th, 2009, 09:02 PM
Pulled the head and the gasket does not look damaged. The #3 piston has a very small hole in the center but it does not go all the way through. It is a perfect hole almost like it was done with a tiny drill bit. Have you ever seen this. Head is straight and I will put on a new gasket. What else should I check for this water problem. It is getting only in the one cylinder. Thanks for you advice.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 evinrude 135 hp needs rebuild in #1 cylinder mcdonkey37 Johnson & Evinrude Outboards 1 June 13th, 2009 03:18 AM
1973 2 cylinder intermittent fire on bottom cylinder. wvmedic Johnson & Evinrude Outboards 2 June 7th, 2009 11:19 PM
1973 25 hp water in cylinder clancy1010 Johnson & Evinrude Outboards 5 June 3rd, 2009 09:28 PM
1973 Evinrude 40Hp seems to run on one cylinder only reilley Johnson & Evinrude Outboards 3 October 1st, 2006 11:25 PM
25hp Evinrude 1973 (aint firing on top cylinder) WTDucks Johnson & Evinrude Outboards 7 August 25th, 2003 03:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
