First indication. It was running perfect and I was running it wide open and it just died. Started hard and idled poor after that. It misses now, and will only hit 2000 RPM in gear.
Background.
Engine overhauled 2 seasons ago from burned pistons, so I checked compression first, and it's OK. Both Carbs had new needle valves and cleaned after engine rebuild. The lower carb was dumping fuel again so I replaced the needle and float today, which solved that problem. I checked the coils, wires, spark, changed plugs with an old set that came out good, changed the fuel filter, the carbs open together, and I rebuilt the fuel pump for the second time today. It has new fuel and vacuum lines which I checked again today. None of this changed a thing.
I didn't bring a timing light, and all the work was done 30 miles from home at the dock, so I can't answer a timing question yet, but I wouldn't think that was the original reason for stalling.
Thanks!
Background.
Thanks!
